Transfluxor
Mar 04, 2021Apprentice
MR2100-TLAUS bug fix
Hello, over the past six months that I have this router, I have received 3 updates, but not a single error that I will write about has been fixed. After every update, I did a factory reset. Also, the...
ArodiD
Mar 10, 2021NETGEAR Expert
Hi There,
Thank you for bringing this to our attention. Our engineers are trying to reproduce this issue. Please keep an eye on your PM's as I may reach out to you with some additional questions on your configurations.
Arodi
Transfluxor
Mar 17, 2021Apprentice
Perhaps I have determined in which case WiFi does not work.
Usually I wake up the MR2100 in the morning by touching the power button, in this case, although I have to wait a long time for awakening, everything works fine. But if I do not touch any buttons and the screen and connect the sleeping router to the USB port of the laptop, then after 1-2 minutes it wakes up by itself but Wi-Fi does not work. Shows a red cross at all times. WiFI starts working only after rebooting the MR2100.
