Transfluxor
Mar 04, 2021Apprentice
MR2100-TLAUS bug fix
Hello, over the past six months that I have this router, I have received 3 updates, but not a single error that I will write about has been fixed. After every update, I did a factory reset. Also, the...
JohnPeng
Jul 24, 2021NETGEAR Expert
Your device is already on the latest FW for Telstra MR2100.
Please advise which carrier you are using in Russia.
Thanks
- TransfluxorNov 29, 2021Apprentice
After the November update of the MR2100-1TLAUS, the router became little more responsive when waking up from sleep. I did not notice the rest of the improvements. The battery icon, also after turning on / rebooting, sometimes may not contain any data. The + sign next to 4G also does not show even when AT !GSTATUS shows aggregation.
Well, and the main "improvement" of the new firmware is the AT command !BAND now, when trying to set only fast B3+B7, it gives an ERROR response. Everything worked in the previous firmware. What good specialists at Netgear now my fast internet periodically switches to super-slow Band 8 and I can't do anything, so I want to smash the router against the wall. If Netgear released a detailed update changer, I would definitely read it and not update it. For me the pluses turned out to be negligible and the minus huge.
