Transfluxor
Mar 04, 2021Apprentice
MR2100-TLAUS bug fix
Hello, over the past six months that I have this router, I have received 3 updates, but not a single error that I will write about has been fixed. After every update, I did a factory reset. Also, the...
Transfluxor
Mar 21, 2022Apprentice
Yesterday my router, after a reboot, froze at point 4 of the boot screen. When I connected USB and LAN at the same time, the router loaded the menu and I did a factory reset, but after that the router also froze at point 4, after which I connected USB and LAN again and even managed to configure the router after reset. But already no interfaces worked - neither USB nor LAN nor Wi-Fi. After the reboot, the router has already frozen at 2 points and blinked a red LED. Now the router only responds to pressing the reset button before power is applied and enters the firmware download mode. Of course, the main problem is that the firmware was removed from free access.
