slimshady21's avatar
slimshady21
MR2100 WIFI OFF IF NO DEVICE PLUGGED
Dear Sirs,
Sorry for my english i am French
i have small a problem with my router ...
When no device is plugged or wifi connected for a long time to the 4G ROUTEUR the router shuts down and the LED is red instead of blue...
I disabled auto WIFI OFF after a long time but this problem occurs..
It's annoying because when i come back to home mi have to open again the ROUTER, to restart my PC for it to detect the WIFI again...
Please kindly help me
Best regards
  • Hi Skytten17
    Kindly check for new firmware update and let us know if it fixed the issue.
    Blanca
    Community Team
  • Hi slimshady21,
    Did you ever get this solved? I am experiencing something similar.
    Morten
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi Skytten17
      Blanca
      Community Team
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Thanks for the reports. This is a known issue and we have a fix for it already.
    Plan to release a new update in the next couple of weeks. Please standby and thanks for your patience. I also received the report from your support team. I will let them know as well on the coming release.
    Regards
