gottadowork's avatar
gottadowork
Follower
Apr 13, 2022
MR5100-1Z1MES Bands
Does anyone know the bands used by the MR5100-1Z1MES from Zain in Kuwait? The only resource I’ve found is at the following link, and I’m not sure it’s correct.
https://wibi.com.kw/products/zain-netgear-nighthawk-m5-router-5g-locked-black
it lists the following bands it supports:
LTE CAT 20,
5G: n2/n5/n25/n41/n66/n71/n78,
LTE: B1/B2/B3/B4/B5/B7/B12/B13/B14/ B25/B29/B30/B38/B41/B46/B48/B66/B71, 3G: B1/B2/B5/B8
  • This is a liar. It does not support most of these band, for example, it does not support N41
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      The list is for NAS SKU.
      For Zain Kuwait, the following bands are supported.
      WCDMA: 1,2,5,8
      LTE; 1,3,7,20
      5G: n1, n78
