jestexman's avatar
Jun 15, 2021
MR5100 5g hotspot 2.4 ghz wifi slow slow
Just recived one of these..   the ethernet is getting around 50 down and 15 up.. 5 ghz is getting about 50 down and 15 up.. 2.4 is getting 10 down and 2 up..
What i am i missing.. This thing is getting double the speed of my Samsung S20+ so that is great.. I am assuming it has to do with the CA.. I would sure hate to have to buy another router to plug into this just to get them speeds.. but it seems that is what i might have to do.
Firmware is up to date.. Running on Att Firstnet..
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Can you manually set 2.4Ghz WiFI's channel to avoid interferences from other WiFi clients? It may help you to improve the 2.4Ghz WiFi TP.
    Thanks
