Rpostma's avatar
Rpostma
Follower
May 05, 2021
MR5100 Band Lock
Does anyone know how to band lock a MR5100 on AT&T.  I have tried the instructions for the MR1100 but they dont work.  I can get into the unit but the band add command does not work.  When I add AT!band=04,"LTE B2",0,2 it returns error.  I can use the AT!band? I get the band info.  Has any one added band locking to this unit.
1 Reply
  • Hi, try adding a space after the AT.
    To make the command look like this AT !Band = 04, "LTE B2", 0.2.
    On my MR2100, the original command also gave an error, it worked with a space.
