Bojasom
Sep 19, 2020Follower
MR5100 last update 1/09/2020
First the router model is MR5100 but it's not showed in the list .. please update so the problem is:- after the last Firmware update (Date: 1/9/2020 ) alot of my device (Oneplus 7 pro / Samsung Not...
mohdwaqas
Oct 14, 2020Aspirant
Bojasom wrote:First the router model is MR5100 but it's not showed in the list .. please update
so the problem is:-
after the last Firmware update (Date: 1/9/2020 ) alot of my device (Oneplus 7 pro / Samsung Note 8 ) unable to find the 5Ghz in dual mode but when i Change it to single bandwith ( only 5Ghz) i can its showing on my devices.
hope they fix it fast.
thank you
hi
Did your problem resolved?
because i have same issue with router.
my router also doesn't show 5ghz on dual band on my any devices from latest firmware update.
