Bojasom
Sep 19, 2020Follower
MR5100 last update 1/09/2020
First the router model is MR5100 but it's not showed in the list .. please update so the problem is:- after the last Firmware update (Date: 1/9/2020 ) alot of my device (Oneplus 7 pro / Samsung Not...
Bravo701
Oct 21, 2020Tutor
michaelkenward wrote:Did you get the manual and read the bit I suggested?
I'm afraid that it is hard to diagnose what is going on from the details you have given us.
You might also like to read the section in the manual Select a WiFi Profile.
He stated in another thread that if he selects dual mode, only 2.4GHz shows up.
But, if he selects single/5GHz, 5GHz shows up.
So, he knows how to change it in settings.
Its just not working as expected.
michaelkenward
Oct 22, 2020Guru - Experienced User
In that case, I'll leave it to that discussion.
It is never a good idea to splatter questions all over the place.
