steadilife
Oct 24, 2020Tutor
MR5100 NO 5G After Firmware Update
On AT&T. Have 2 M5s and had 5G almost everywhere in my area. Received a firmware update last week on both and no longer have 5G, but rather 5ge. Tried reboots, factory resets charging to full, spee...
steadilife
Oct 25, 2020Tutor
Thanks for the quick reply.
Both MR5100 (M5’s) auto updated to NTGX55_10.25.15.02.
Confirming again today that both at avoiding 5G over 5Ge at all costs.
nazoren
Nov 10, 2020Aspirant
Hello,
Is there any update on this?
Experiencing the exact same issue, after the new NTGX55_10.25.15.02 firmware not getting 5G signal or the speed.
Before all was perfect 90-95 Mbps speeds came down to 20-30 Mbps...
Is this a ATT throttling update ?
- steadilifeNov 10, 2020Tutor
I'm working with their support right now to figure out what is going on. So far their support in multiple conversations has been able to figure out that I've tried multiple sim cards and it still isn't connecting to 5G. So hopefully soon we can make it to tackling the actual cause. I'll post an update here as soon as I hear something back.
- nazorenNov 10, 2020Aspirant
Thanks steadilife
hopefully solution is on the way...Will be checking with ATT and Netgear for any solution as well.
To rollback to old working firmware looks like an easy fix but there is no way to install with the MR5100 interface - Blanca_ODec 01, 2020NETGEAR Employee Retired
