Jayka10's avatar
Jayka10
Follower
Nov 10, 2022
MR5100 not booting up
Hoping someone can shed a little light for me:  hotspot starts to boot up (battery fully charged, btw), and screen shows "Netgear", that fades, then comes back on - repeats about four times and then becomes unresponsive.  Have tried doing a reset, but nothing seems to happen.  If I remove battery and then replace, it will only repeat the above action.  Anybody else ever have this issue?  Ideas?  Thanks in advance!
  • Have you tried using ac power? My 6500 was doing this without the battery and plugged in, I then kept messing with it until it finally stayed on with no battery and ac power
  • Have you tried a factory reset while plugged in and hitting reset button?
