meloserj
Aug 01, 2023Aspirant
MR5100 throttles download speed on ethernet upon using IP passthrough
Hello mates When I am activating IP Passthrough on my MR5100 for static WAN IP, and use the ethernet port, the download speed throttles to max 200 Mbps although my backbone is 5G and I have 700-8...
- Aug 28, 2023
you are right 😞 , this is due to different design M5 vs M6.
schumaku
Aug 13, 2023Guru - Experienced User
meloserj wrote:
As the issue seems resolved in MR6xxx series, hope there would be some small modifications in firmware to make a customization on MR5100.
I'm not convinced this is fully fixed. Several recent reports of slower performance in about the 500 Mb/s range there.
mcuadrado
Aug 28, 2023Guide
Hello, yes, I can confirm issue with IPT and ethernet is resovled in M6 series.
- mcuadradoAug 28, 2023Guide
- meloserjAug 28, 2023Aspirant
Thanks for confirmation, sadly I should sell my M5 and go for RM520-GL modems although so far I have had 3 Netgear Nighthawk routers 😞
may I ask why you need IPT , as you can have NAT with DMZ with full tput ?
Have web servers at home and have Public IP, tried to put my home router in DMZ of M5, some ports never opened. I had to do port forwarding on M5 for making it.
Also for XBOX, the same solution I applied.
In general, Netgear should think about this before releasing M5 and throttled the speed. When my tower delivers 700-800 Mbps, so why I couldn't use the IPTT?
In M1, I was sure that having 200Mbps is somehow perfect in LTE, but when you pay for M5 and 5G, then this throttling is not acceptable.
