CBCrosby8155
Feb 25, 2021Aspirant
MR5100 won't connect to Windows 10 pc
My MR5100 will not connect to my Dell XPS desktop with Windows 10. When it shows up as available it is listed as "hidden ". I go thru set-up: ssid, password, etc and get message it won't connect. PC h...
michaelkenward
Feb 26, 2021Guru - Experienced User
CBCrosby8155 wrote:
Router connects to all other devices, including a windows 10 Dell laptop
First, the router does not connect to devices. It is the other way round. Devices connect to the router. I mention that because that tells you where to start looking.
You were on the right lines when you talked to Microsoft. That sounds like a local network setting in Windows on the Dell XPS desktop.
This hints that you are talking about wifi here. Maybe not. Have you tried wired?
CBCrosby8155 wrote:
Worked with Microsoft today, they couldn't solve.
Did that include running the network troubleshooter in Windows?
CBCrosby8155 wrote:
PC has Intel AC 7260 network board.
Tried looking at the Intel site for drivers?
Then there is this:
Search - NETGEAR Communities – Intel AC 7260
CBCrosby8155
Mar 03, 2021Aspirant
Windows did a quite thorough look at the system, including changing the settings, all without success.
- ArodiDMar 03, 2021NETGEAR Expert
Hi CBCrosby8155 ,
Are you saying that USB, Ethernet or WiFi connectivity is not working with Windows 10 PC and MR5100? If all connection types fail, are you able to provide some detail on the failure? (i.e No internet or PC just doesnt recognise no matter what)
- CBCrosby8155Mar 03, 2021AspirantThanks. My Windows desktop won't connect to the MR5100, whether via wifi, when connected via USB cable or connected via ethernet cable. The ethernet on the pc is functioning properly as are the USB ports.
All my other devices connect to the MR5100 via wifi without issue which tells me it is something going on with the wifi card in my pc. I contacted Dell and they indicated that my Intel AC 7260 was not compatible with the MR5100. It is an older pc, about 7 yrs old, but, it connected to previous internet providers routers and connects to my Verizon Jetpack that I currently use for wifi until I can get this figured out.
Hope this answers your questions. Thanks- michaelkenwardMar 04, 2021Guru - Experienced User
CBCrosby8155 wrote:
Thanks. My Windows desktop won't connect to the MR5100, whether via wifi, when connected via USB cable or connected via ethernet cable.What prevents the connection? Windows?
What messages do you see?
Have you tried running the Windows network troubleshooter?
Windows likes to protect us from new networks that might be evil. In reality, it often shuts us out of safe networks.
One thought is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I'm told that this is rubbish advice. But it has worked for me and others in the same boat.
- CBCrosby8155Mar 03, 2021AspirantAdditionally, when I go into set up a new wifi, I go thru all the normal setuo- enter ssid, password, etc and get message that it can't connect.
Hi CBCrosby8155 ,
Have you configured the M5 to not broadcast SSID and this is the reason you manually have to input SSID and Password on Windows Desktop? Or is the M5 broadcasting the SSID as normal but it just does not show on the Windows Desktop list of available WiFi networks?
Arodi
