stryker6040
Feb 04, 2023Aspirant
MR5200 -100NAS Slow/no date output
Hello all I have a MR5200 that is less than six months old and out of the blue it quit outputting data. I am using a sim that is not IMEI locked so I can take the sim out and put it in another device...
stryker6040
Feb 10, 2023Aspirant
Any reps from Netgear care to chime in. I have tried multiple other provider sims other the last week and ruling out any type of network issues.
I essentially have a multi hundred dollar paper weight currently. Again this release came out after the long back order of these started shipping out this fall just before the release of the 6000 series.
- JohnPengFeb 15, 2023NETGEAR Expert
Could you please confirm what carrier SIM you are using and what's plan on it?
As we know, T-Mobile cellphone plan will be throttled when you use it on mobile hotspot type of device. Not sure you are seeing the same issue.
Thanks
John
