W1lliam's avatar
W1lliam
Virtuoso
Nov 03, 2021
MR5200-100EUS panel information display bug
M5 is not displaying correct information on its panel, while two devices (one for WiFi another for Ethernet) connected but only display one device is connected. Web interface is displaying correct information but the Panel isn't. Can this be fixed for next FW release?
  • Hi W1lliam ;
    On LCD, the number displayed is really means the number of WiFi clients.
    This is by design I think.
    Thanks
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi W1lliam
    Thanks for bringing this to our attention. Let me check on this. I will get back to you for any updates.
    Blanca
    Community Team
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Hi W1lliam ;
    Thanks
