H24423
Apr 24, 2023Aspirant
MR5200-100EUS wont connect to network
Hi, My Netgear MR5200-100EUS _04.02.196.00 will not connect to the network. Stuck in searching for carrier. I have tested with SIM cards from two different providers. SIM cards work fine on mobi...
brent-m5
May 14, 2023Aspirant
Hi H24423 I am having the same issue with my M5 - did you manage to find out what the cause of your problem is?
My post is at https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/Netgear-M5-MR5200-100EUS-issues-in-Australia/td-p/2312516
Thanks đ
