breaker160's avatar
breaker160
MR5200-100NAS vs MR5200-100EUS
Hello,  I live in Europe and I plan to buy a MR5200 router, but I don't understand the difference between those two model "MR5200-100NAS", "MR5200-100EUS". Can someone explain which model, should I...
  • W1lliam's avatar
    Aug 30, 2023
    Below is supported bands for each model
    MR5100-100NAS -
    WCDMA:B1+B2+B5+B8
    LTE:b1+b2+b3+b4+b5+b7+b8+b12+b13+b14+b17+b25+b26+b29+b30+b38+b39+b40+b41+b46+b48+b66+b71
    NR5G:n2+n5+n25+n38+n41+n48+n66+n71+n77+n78
    MR5200-100EUS
    WCDMA:B1+B2+B5+B8
    LTE:b1+b3+b5+b7+b8+b20+b28+b38+b40+b41+b42
    NR5G:n1+n3+n5+n7+n8+n20+n28+n38+n40+n77+n78
    It looks NR5200-100NAS does have wider support for LTE, but if you are looking for NR5G service at European, MR5200-100EUS would be more appropriated.
