andrevme
Aug 15, 2022Follower
MR5200 as a bridge/modem for Unifi Dream Machine (UDM)
Hey Guys, I've just bought a MR5200 as a 5G modem for my Unifi Dream Machine System. Before using this one we had a LM1200 4G in bridge mode working well with the UDM. As I read The MR5200 d...
hughes26301
Aug 16, 2022Aspirant
Connect the computer directly to the modem Ethernet (LAN) port.
Click Start > Run > Type cmd (command for Windows) and press Enter.
On the command prompt, type ipconfig and hit Enter.
To view your IP address on Mac computers or Windows 8, see What is the IP address of my NETGEAR router?
If the IP Address displayed under Ethernet Adapter Local Area Connection is either 192.168.x.x or 10.0.x.x, then the modem should be bridged.
Call your Internet Service Provider to set the modem to bridge mode.
You can also try changing LAN IP address of router.
Log in to the router user interface and change IP address to 192.168.2.1 or 10.0.0.1 under LAN Setup (ADVANCED > Setup > LAN Setup).
