studiobrain
Aug 04, 2022Follower
MR5200 compatible mesh
What is or is there a recommended compatible mesh for the MR2500?
I have 3 google pucks but have read that these will not be compatible; I have not been able to get the wifi through the pucks when attempting in the past.
1 Reply
You should be able to get your pucks to work with it. You'd want to put their ip address into the MR5200 dmz.
(page 50 of the manual)
