Dominique73's avatar
Dominique73
MR5200 configuration
Hello,
I intend to replace my 4G MR1100 by the new 5G MR5200.
Can I import my current MR1100 configuration (.cfg file) into the  MR5200 to keep all my network settings ?
Thank you
1 Reply
  • plemans's avatar
    I wouldn't.
    Its different hardware.
    I'd just write down what you're settings are and transfer them over that route.
    Helps prevent instability.
