ur2one
Aug 05, 2023Aspirant
MR5200 data usage per equipement ?
Hello How can I identify which equipment / MAC ADDRESS is using data on my nighthawk M5? (I am currently having huge data consumption and I cannot find which equipment is responsible for this...) T...
microchip8
Aug 05, 2023Master
Data usage per device monitoring is not supported by stock NETGEAR firmware.
- ur2oneAug 05, 2023AspirantThanks. Where can I guest custom firmware for MR5200 ?
- microchip8Aug 05, 2023MasterThere is none.
- michaelkenwardAug 05, 2023Guru - Experienced User
ur2one wrote:
Thanks. Where can I guest custom firmware for MR5200 ?You will not get "custom firmware" here, even if it existed. Netgear will only supply "official" firmware.
And, as explained, it will it not help with your first request.
There could be other ways to track down the culprit. Perhaps you could say what it might be.
