Nate2021's avatar
Nate2021
Follower
Jun 06, 2022
MR5200 Incorrect Wifi Mobile Router
Netgear Mobile App on Android (Google Play) says "Mobile Router is not supported by the Netgear Mobile App". I factory reset which did not solve the problem. Works on iOS, but not Android.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Nate2021,
    Welcome to NETGEAR Community!
    Are you still experiencing this?
    Please provide the Mobile app Android version that you have downloaded.
    Blanca
    Community Team
