Rvision
Sep 05, 2022Aspirant
MR5200 M5 Not connecting to 5G - iPhone can connect fine with same SIM
I am having problems connecting to 5G on the M5 and sometimes get the error that there is no network connection. Device displays 5G but band never changes from LTE, my iPhone 13 with the same SIM...
Rvision
Sep 06, 2022Aspirant
So I just installed a Globe 5G SIM and performance very good, NR5G service is attached. curband still LTE even though M5 display flicks between 5G and 4G+.
So for the other carrier it looks like SMART are blocking the M5 device on my current plan or there is a compatibility issue.
Does anyone know if there is anyway to spoof the Netgear device to be an iPhone, e.g change the IMEI number to my apple iPhone, is that going to be enough?
"diagInfo": [ {
"lteAttached": true,
"nr5gAttached": true,
"currentNWserviceType": "Nr5gService",
"curBand":"LTE B8",
Rvision
Globe JSON
