GrahameT
Sep 01, 2022Follower
MR5200 M5
Just bought this model , have a EE 5G unlimited SIM , on set up it telling me I need to input the APN. Called EE they said I need to get this from NETGEAR - How do I go about this and is this right.
michaelkenward
Sep 01, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. The MR5200 is not one of the standard routers covered here. It is a mobile modem/hotspot.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
