christhirteen13
Mar 28, 2021Follower
MR5200 Manual Band Selection
Dear Community,
I have bought the Netgear MR5200 (M5) and I have been trying to switch bands manually on it using a Telnet connection. It seems that the commands which work for the MR2100 and the MR1100 don't work for the MR5200.. It will not respond in the same way. Does anyone know which commands actually work. It would help a lot.
Best,
Chris
1 Reply
- W1lliamVirtuoso
there is a free tool to assist band locking, and some other useful task, at https://mega.nz/folder/DCoXXSpJ#CrBiM28fP-3Zml1_XNclxA
you can try with this, I can do it with MR5200-100EUS
