savvyaviator
May 11, 2022Aspirant
MR5200 mobile 5G hotspot -- IP Passthrough mode
AT&T set me up with a Netgear MR5200 mobile 5G hotspot. It's working as advertised. However, what I want to do is to use it as a 5G modem and connect it to my whole-home Wi-Fi mesh network (which is ...
JohnPeng
May 15, 2022NETGEAR Expert
Sorry. This is the limitation of IP Passthrough on M5. But I think in router mode, you should be able to connect your mesh system if double NAT is not an issue to you.
savvyaviator wrote:
AT&T set me up with a Netgear MR5200 mobile 5G hotspot. It's working as advertised. However, what I want to do is to use it as a 5G modem and connect it to my whole-home Wi-Fi mesh network (which is a Linksys Velop system). If I simply connect the MR5200 to the Linksys Velop via an Ethernet cable, it doesn't work -- presumably because of double-NAT issues.
If I connect a browser to 192.168.1.1 and reconfigure the MR5200 by turning on IP passthrough and turning off DHCP, then it does seem to work properly as a modem interfaced by Ethernet to my Linksys Velop system. It appears that this must be done via the WebGUI and cannot be done from the screen of the MR5200.
However, when I do that, I lose the ability to administer the MR5200. It no longer responds to 192.168.1.1. I even tried connecting its USB-C port to my Windows laptop (to "tether" it) but it still doesn't respond. The only way I've been able to administer it is to perform a factory reset from the MR5200 screen and then reconfigure it all over again.
Is there a better way? Is there some way to get administrative access to the MR5200 when it is in IP passthrough mode?
