savvyaviator
May 11, 2022Aspirant
MR5200 mobile 5G hotspot -- IP Passthrough mode
AT&T set me up with a Netgear MR5200 mobile 5G hotspot. It's working as advertised. However, what I want to do is to use it as a 5G modem and connect it to my whole-home Wi-Fi mesh network (which is ...
Ksa3344
May 16, 2022Apprentice
im not sure if the following will help
after enabling IP Passthrough link the M5 to your laptop or PC by USB C cable
go to settings from the webpage -Router settings
youll find LTE Subnetmasc this settings appears only after you enable Passthrough
change the value from 255.0.0.0 to 255.255.255.0
