savvyaviator
May 11, 2022Aspirant
MR5200 mobile 5G hotspot -- IP Passthrough mode
AT&T set me up with a Netgear MR5200 mobile 5G hotspot. It's working as advertised. However, what I want to do is to use it as a 5G modem and connect it to my whole-home Wi-Fi mesh network (which is ...
Ksa3344
May 16, 2022Apprentice
im not sure if the following will help
after enabling IP Passthrough link the M5 to your laptop or PC by USB C cable
go to settings from the webpage -Router settings
youll find LTE Subnetmasc this settings appears only after you enable Passthrough
change the value from 255.0.0.0 to 255.255.255.0
savvyaviator
May 16, 2022Aspirant
I'm not clear on how to access the router settings after connecting the USB cable to my computer. What do I type in the browser URL window to get there? 192.168.0.1 and 192.168.1.1 definitely did not work.
- Ksa3344May 16, 2022ApprenticeOk i just relised that its working with you but your problem entering the webpage.
First you can plug your router directly to the pc and i assure you it will work thats for your question.
second
I got a problem like that with TP link Deco M5
after lot of web searching i found that some mesh routers sees the IPs staring with 192 as a Class 3 IPs and it doesn't work with them .
so i changed my webpage ip from
192.168.1.1 to 10.0.0.1 on my 5g router
or try 127.0.0.1
You can change the ip fro netgear settings page
Go to the page then
Settings-Setup-Mobile Router Setup.
