savvyaviator
May 11, 2022Aspirant
MR5200 mobile 5G hotspot -- IP Passthrough mode
AT&T set me up with a Netgear MR5200 mobile 5G hotspot. It's working as advertised. However, what I want to do is to use it as a 5G modem and connect it to my whole-home Wi-Fi mesh network (which is ...
savvyaviator
May 16, 2022Aspirant
I'm not clear on how to access the router settings after connecting the USB cable to my computer. What do I type in the browser URL window to get there? 192.168.0.1 and 192.168.1.1 definitely did not work.
Ksa3344
May 16, 2022Apprentice
Ok i just relised that its working with you but your problem entering the webpage.
First you can plug your router directly to the pc and i assure you it will work thats for your question.
second
I got a problem like that with TP link Deco M5
after lot of web searching i found that some mesh routers sees the IPs staring with 192 as a Class 3 IPs and it doesn't work with them .
so i changed my webpage ip from
192.168.1.1 to 10.0.0.1 on my 5g router
or try 127.0.0.1
You can change the ip fro netgear settings page
Go to the page then
Settings-Setup-Mobile Router Setup.
second
or try 127.0.0.1
Go to the page then
