Samsterx777
Mar 16, 2023Aspirant
MR5200 Suddenly Having bad Connection - Signal is excellent, etc
Yesterday 3/15/2023, my Nighthawk suddently stopped working was VERY spotty connection (ruined my work day). I was in a town with good internet connection. I've tried the SIM card in another hotspot...
JohnPeng
Mar 17, 2023NETGEAR Expert
Based on the log, your device connected to T-Mo network with B2+n41. But somehow n41 signal is really bad. Is there any change recently on T-Mo network? What's the other mobile hotspot you are using? Please provide the brand and model if possible.
Looks like a network related issue. You can try at another location and see whether the device can work better.
Thanks
Samsterx777
Mar 17, 2023Aspirant
I appreciate your response. The other device is a Franklin T9 (smaller and normally less powerful).
I appreciate the help! I'm wondering if something if not working right within the hardware or if it's a firmware issue.
- JohnPengMar 17, 2023NETGEAR Expert
I appreciate the help! I'm wondering if something if not working right within the hardware or if it's a firmware issue.Franklin T9 is LTE only device. The current issue seems on T-Mo network with 5G support. You can force the device to connect to LTE only network for now by selecting Band Region as LTE only and check back later whether 5G can at your area.
Thanks
John
- Samsterx777Mar 17, 2023AspirantI tried that before I believe, but should I turn roaming off or anything as well?
Samsterx777 wrote:
I tried that before I believe, but should I turn roaming off or anything as well?If you connected to T-Mo home network work, roaming setup doesn't really change anything.
Thanks
- Samsterx777Mar 17, 2023AspirantThanks, That is working! It says there are full bars 5g available though, so still odd, but that's a good step towards a solution.
- Samsterx777Mar 17, 2023Aspirant-97 dBm for rsrp still when on 4g, but still able to function at least.
