jslcom's avatar
jslcom
Guide
May 11, 2023
MR5200 US Firmware Upgrade Available Yet?
As discussed over two months ago here: https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/Nighthawk-MR5200-M5-We-need-your-feedback/m-p/2299667/highlight/true#M23866, I'm still waiting for the announced firmware upgrade.  My product is presently running firmware version NTGX55_12.04.17.00, which is from 2021.  The above thread was closed and marked "solved", so I assume all described issues will be addressed in the new firmware upgrade.  My MR5200 shows "Up to date - Last checked 5/11/23 8:40 AM" with the above mentioned firmware version.
When can we expect the release of the new US firmware?
Jeff
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      FW 12.04.17.00 is already the latest release with the ethernet port stability fix. The PRI version should be 03.00.
      As for the built timestamp, I will check whether it was a typo. The FW was build on March 1, 2023.
      Thanks
