dotbill
Jul 23, 2021Tutor
MR5200 won't attach to n77 after firmware update - multiple questions!
I have a number of MR5200 that I use for testing locally on a local network... The old firmware (NTGX55_10.29.11.00) worked really well on my band 3 / n77 5G NSA setup however a newer firmware that g...
JohnPeng
Sep 29, 2021NETGEAR Expert
jzz15 wrote:
Same problem
After upgrade to NTGX55_12.03.09.00
I can only use 4G+
Before upgrade, I can use 5G with china telecom and china unicom.
Also in model.json,
i get same result:
"nr5gsigRsrp": "-32768 dBm",
"nr5gsigRsrq": "-32768 dB",
"nr5gsigSnr": "-3276 dB"
We have a MR release coming out next week to address the issue. Please standby.
jzz15
Sep 29, 2021Aspirant
Thanks John Peng!
Hope new firmware can fix this!
because my iPhone12 Pro(also qualcomm x55) works fine with 5G at same place.
