Tshotton12345
Dec 16, 2024Aspirant
Mr5200
Hello I hope someone can help I have a mr5200 nighthawk and trying to access it remotely as in away from the network, been trying to use Netgear insight portal but getting nowhere even though there site says it’s compatable to use remote management, hope someone can help
usually hotspots need the mobile app for access. Not sure if you'll be able to set it up since you aren't there for initial connection though.
https://www.netgear.com/support/product/netgear-mobile-app/
- Tshotton12345AspirantI am there but just want to be able to access it remotely at any time
Try it.
Install it, turn off the wifi and see if you can manage it. I've never really tried.
Several different Netgear Mobile Hotpot models listed here https://www.netgear.com/business/services/insight/devices/ plemans
Tshotton12345 please tell us more about the MR5200 model (exact model designation as printed under the battery), the current firmware version, the mobile provider, ...
