cottagefarmer
Jun 28, 2022Follower
MR6100 - IP Passthrough isn't working
Hi, hope everyone is having fun today. Although I can sometimes get the MR6 to work as a regular hotspot, once I put it in IP Passthrough mode it will not even connect to a tower, it is just "searchi...
DevOps
Jul 07, 2022Aspirant
How did you get the MR6100 into passthrough mode? I can find that setting.
As for the other reply about this being the wrong forum, this is the location the Netgear web interface drops you into when navigating the help option.
- michaelkenwardJul 08, 2022Guru - Experienced User
Is there a mistake in there?
"Can't find"?
What is your idea of "passthrough mode"? Like "bridge mode" it is one of those terms that means different things to different people and depends on the context.
It is not something usually associated with Mobile Routers, Hotspots & Modems.
You might do better to start by explaining what you are trying to achieve rather than looking for possible "solutions".
For example, are you trying to use your MR6100 with another router?
It was moved.
It would be good to known which help option?
