ASM92
Jul 01, 2024Follower
MR6110 Doesn't work on 5G N78
Hi experts,
I have an issue with my router, where it can't connect to the 5G network in my country.
my model is MR6110-1A1NAS, and i have changed the firmware to another model firmware which is "MR6110-1S4MES". but still it can't connect to the 5G network.
Can I add the N78 to the BAND list of the router?
I have used "AT!BAND=?" command to list the bands available but there is no support for N78:
at!band=?
Index, Name, GW_Mask LTE_1-64 LTE_65-128 NSA_1-64 NSA_65-128 NSA_257-320 SA_1-64 SA_65-128 SA_257-320 Mode
00, All, 0002000000400000 0000000000000045 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0
02, LTE All, 0000000000000000 0000000000000045 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 1
03, LTE and NR5G, 0000000000000000 0000000000000045 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0
0000800000000000 - LTE B48
0000200000000000 - LTE B46
0000000020000000 - LTE B30
0000000010000000 - LTE B29
0000000000002000 - LTE B14
0000000000000800 - LTE B12
0000000000000040 - LTE B7
0000000000000010 - LTE B5
0000000000000008 - LTE B4
0000000000000004 - LTE B3
0000000000000002 - LTE B2
0000000000000001 - LTE B1
0000000000000002 - LTE B66
0000000020000000 - NR5G N30
0000000010000000 - NR5G N29
0000000000002000 - NR5G N14
0000000000000800 - NR5G N12
0000000000000010 - NR5G N5
0000000000000002 - NR5G N2
0000000000001000 - NR5G N77
0000000000000002 - NR5G N66
- smithjohns00200Aspirant
thanks iys very helpful
- W1lliamVirtuoso
MR6110-1A1NAS is built for ATT service which has no n78. When you are doing hack on its FW, it might damage the device from its function perspective, not even to enable bands that is not built for the device.
