JackNugget35
May 15, 2024Follower
MR6110 is blocking the canon printer
my Nighthawk is blocking the Canon Pixma printer to the wifi.
1 Reply
What tells you that? Some error messages somewhere?
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
