holybanjo
Jan 27, 2025Guide
MR6110 Unable to connect
Hello I’m getting the message “unable to connect to network” when I enter the WiFi password for the MR6110. Please advise Matthew
- Jan 28, 2025
wow you look at the reviews for that card on an AX network and its a ton of posts with issues.
here's one specifically https://www.reddit.com/r/techsupport/comments/n2cpiv/is_there_a_problem_with_the_realtek_8822ce/
I'm a fan of intel cards (other than their new BE200 because its not compatible with AMD). If you're half hand, you can pickup a cheap Intel AX210 and put in your laptop. Or even try a cheap USB wireless adapter. That'll tell you real quick if the card is the issue.
Jan 27, 2025Guru - Experienced User
well, it could be the wrong password.
Do all devices have issues or just one?
Did you go in and check the password?
Or try changing it?
- holybanjoJan 27, 2025GuideIt works with every other device except my laptop.
- plemansJan 27, 2025Guru - Experienced User
1. what wireless card in the laptop?
2. what security method are you using on the router? wpa2? wpa3? wpa2/wpa3 mixed mode?
3. Seems strange that everything works fine except for 1 device. Tends to indicate a device issue and not MR6110 issue.
- holybanjoJan 28, 2025GuideMy laptop has the following wireless hardware:
Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
Driver version: 2024.10.141.0- plemansJan 28, 2025Guru - Experienced User
Thanks for this. I've tried it with my USB adaptor and lo-behold, it works. Will I be able to upgrade to the Intel AX210 on an ASUS lapop? Or would I be better placed just getting a new laptop?
