holybanjo
Jan 27, 2025Guide
MR6110 Unable to connect
Hello I’m getting the message “unable to connect to network” when I enter the WiFi password for the MR6110. Please advise Matthew
- Jan 28, 2025
wow you look at the reviews for that card on an AX network and its a ton of posts with issues.
here's one specifically https://www.reddit.com/r/techsupport/comments/n2cpiv/is_there_a_problem_with_the_realtek_8822ce/
I'm a fan of intel cards (other than their new BE200 because its not compatible with AMD). If you're half hand, you can pickup a cheap Intel AX210 and put in your laptop. Or even try a cheap USB wireless adapter. That'll tell you real quick if the card is the issue.
holybanjo
Jan 27, 2025Guide
It works with every other device except my laptop.
Jan 27, 2025Guru - Experienced User
1. what wireless card in the laptop?
2. what security method are you using on the router? wpa2? wpa3? wpa2/wpa3 mixed mode?
3. Seems strange that everything works fine except for 1 device. Tends to indicate a device issue and not MR6110 issue.
