holybanjo
Jan 27, 2025Guide
MR6110 Unable to connect
Hello I’m getting the message “unable to connect to network” when I enter the WiFi password for the MR6110. Please advise Matthew
- Jan 28, 2025
wow you look at the reviews for that card on an AX network and its a ton of posts with issues.
here's one specifically https://www.reddit.com/r/techsupport/comments/n2cpiv/is_there_a_problem_with_the_realtek_8822ce/
I'm a fan of intel cards (other than their new BE200 because its not compatible with AMD). If you're half hand, you can pickup a cheap Intel AX210 and put in your laptop. Or even try a cheap USB wireless adapter. That'll tell you real quick if the card is the issue.
nevdowling
Jun 23, 2025Aspirant
I'm seeing the same message intermittently attempting to connect iPhone and iPads to Nighthawk M6 Mobile Router (MR6110 Telstra) in Qld Australia. Netgear support tell me to contact Telstra although the device was bought at JB Hi-FI although it uses the Telstra Network. I've connected to the router admin page from my desktop computer and checked the firmware (NTGX65_12.01.41.00) but Netgear support hasn't confirmed if there's any problems with this firmware when using the Telstra 5G network
