Richardbs's avatar
Richardbs
MR6110
I have a MR6110 router i need the model number for the AC adapter as i need a replacement AC adapter, can anyone help me with this information in Australia?
Thanks
  • michaelkenward's avatar
    michaelkenward
    Netgear does not sell replacement power adapters in most countries. Any generic transformer should work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
    The details you need should be on the old adapter, on a label on the device itself and in its manual.
    You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
    Some generic adapters come with a set of tips that will fit a range of different devices.
    If you can't find these details, then a better place to ask for help might be the section given over to these devices:
    Cell Service Mobile Hotspot Modems, AirCards, & Mobile Routers - NETGEAR Communities
    • Richardbs's avatar
      Richardbs
      Thanks for your help with this information. I now realise I need an adapter with 5v and 9v output to run the router with no battery. Netgear support was bad as they could not provide this basic information.  Regards Richard
        michaelkenward
        That sounds odd 5v and 9v?
        But I don't have one of these mobile modem/routers.
