goswh's avatar
goswh
Tutor
Apr 05, 2024
MR6150 - Change LAN IP Range?
Hello.
The MR6150 defaults to using an RFC1918 private address range for DHCP to clients (192.168.1.0/24).
I need to change this to use something different.  After looking in the device menu & settings, there doesn't appear to be a way to update the LAN IP Range. I looked in the Mobile Netgear app on my iPhone to see if it had a setting for this and I didn't find anything it either.
So how to we change the default 192.168.1.0/24?
Thank you.
//Shawn
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi goswh,
    Welcome to NETGEAR Community!
    Kindly access M6 Web UI, go to Settings > Setup > Mobile Router Setup.
    Blanca
    Community Team
