chrodroid
Jul 17, 2023Guide
MR6150 firmware 12.01.29.00 review Glorified MR1100 LTE
For the past 5 days I have been reviewing the upcoming MR6150 12.01.29.00 firmware (not sure if this is final or beta) With T mobile service The MR6150 never connect to 5G service in fact it keep fa...
JohnPeng
Oct 24, 2023NETGEAR Expert
chrodroid wrote:
For the past 5 days I have been reviewing the upcoming MR6150 12.01.29.00 firmware (not sure if this is final or beta) With T mobile service The MR6150 never connect to 5G service in fact it keep falling into LTE and speed barely reach 100. This happens in 3 different cities and states.basically it becomes an overprice MR 1100.
Current firmware 10.04.22.00 it will connect to 5g service and the speed range between 300-500 with the same sim card from T-mobile. again this is tested in 3 different cities and states. It does have quirk the modem wont stay on over 2 days. it will either turn off or rebooting. So make sure you have battery inside.
So if you like the speed AVOID the update until they fix it, cause you have no recourse to downgrade . But if you want stability BUY MR1100 instead which is known for stability and affordability 🙂
Could you please send me the model.json file when using T-Mobile SIM?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
You can email me at jopeng@yahoo.com with your community ID.
Thanks
John
JohnPeng
Anyone in this thread, please do the following if you have issues with your MR6150 on T-Mobile.
Thanks
John
- MyFriendSantaOct 24, 2023StarUnfortunately I am still waiting on vendor support to send over the original firmware file that came with my purchased device. As soon as I receive the .spk file I and many others have requested, I will send a copy of my .json file.
I personally see no reason netgear cant boot up two different devices with different firmware or look at their raw code libraries to determine a fix.
No idea why it falls on the customers to work on the failed update that got rolled out.- anjeshOct 25, 2023Tutor
from what i've read on other forums, this update "fuzzed" (my understanding and has encrypted/locked down) the device and this upgrade is a one way change. there is no option to downgrade completely to the old firmware.
- JohnPengOct 25, 2023NETGEAR Expert
With every release, our goal is to improve the device stability, address the security issues, fixed the performance and functional issues and also introduce new features. If there are any new issues introduced, we would like to work with the customers to resolve them, instead of rolling back to the old releases.
If you have any suggestions or find any issues, please don't hesitate to reach out to me.
Thanks
