igorjrr
Jan 10, 2023Apprentice
MR6400 many many many issues
Are we testing a several hundred dollars device paying for it? - turns on airplane mode by itself, usually right after first time logging in to admin page. - wifi broadcast stops. Wifi shows as on...
igorjrr
- wifi broadcast stops. Wifi shows as on in device, but it doesn't broadcast.
- turns off ethernet by itself.
- mobile connection disconnects randomly, shows as connected on LCD but disconnected on admin page.
Basically it has a life of its own.
The firmware version is from more than 6 months ago, and it says it's up to date!
Version NTGX65_10.01.41.02
Absolutely horrible.
night64
Jan 11, 2023Aspirant
Hello
if you have so many issues you can reset it
With the Router powered on, press and hold the WPS/RESET button (more than 10 seconds) until the SYS LED becomes quick-flash from slow-flash. Then release the button and wait the Router to reboot to its factory default settings.
may be come down your issues.
- igorjrrJan 11, 2023Apprentice
Thanks, but it's new. It seems very clearly to be bad firmware (I see other reports of MR6400 being very unstable).
We are paying to be testers of this product.
- night64Jan 11, 2023Aspirant
Hope so you got your solution
- igorjrrJan 28, 2023ApprenticeSeems like this firmware improved nothing.
Another evidence this hotspot is unfinished but sold at a high cost.
Nice job.
