igorjrr
Jan 10, 2023Apprentice
MR6400 many many many issues
Are we testing a several hundred dollars device paying for it? - turns on airplane mode by itself, usually right after first time logging in to admin page. - wifi broadcast stops. Wifi shows as on...
michaelkenward
Jan 11, 2023Guru - Experienced User
The MR6400 is not one of the WiFi 6 routers covered here.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
