igorjrr
Jan 10, 2023Apprentice
MR6400 many many many issues
Are we testing a several hundred dollars device paying for it? - turns on airplane mode by itself, usually right after first time logging in to admin page. - wifi broadcast stops. Wifi shows as on...
night64
Jan 11, 2023Aspirant
Hello
if you have so many issues you can reset it
With the Router powered on, press and hold the WPS/RESET button (more than 10 seconds) until the SYS LED becomes quick-flash from slow-flash. Then release the button and wait the Router to reboot to its factory default settings.
may be come down your issues.
igorjrr
Jan 11, 2023Apprentice
Thanks, but it's new. It seems very clearly to be bad firmware (I see other reports of MR6400 being very unstable).
We are paying to be testers of this product.
