W1lliam
Apr 18, 2023Virtuoso
MR6450-100EUS only connects 4G service
Is it MR6450-100EUS FW NTGX65_12.01.05.00 still under developing? Same SIM card, same spot, MR5200-100EUS, with FW NTGX55_12.04.17.00 can connect 5GNR service but MR6450 doesn't, only 4G+ Any twe...
W1lliam
Jun 23, 2023Virtuoso
JohnPeng
Jul 11, 2023NETGEAR Expert
W1lliam wrote:
JohnPeng
Is there any planned schedule for FW update which can resolve this issue?
The internal testing is ongoing and the maintenance release to address the issue will be released around 7/21.
Thanks
- W1lliamJul 12, 2023Virtuoso
Hi JohnPeng ,
Just got my MR6550-100PAS and found it has same problem as MR6450-100EUS, only connecting at 4G LTE and no NR5G service, should be the same cause, would you please also help to take a look at this? If you need me to provide any information, please do not hesitated to contact me, thanks
PS. Actually MR6110-1TLAUS/MR6500-1TLAUS (all supporting n78) also can't support NR5G service here in Taiwan, should be all on same cause as MR6450-100EUS.
William
- JohnPengJul 12, 2023NETGEAR Expert
W1lliam Could you please advise which carrier you are using with the MR6550? If possible, could you please send me the model.json file at [email protected]?
I can set the device to upgrade to our next MR release candidate. You can help to verify whether the issue can be resolved.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
John
