jraffel
Mar 04, 2023Aspirant
MR6450 and MacBook M2 don't connect on 6GHz
Hi Netgear, I got the new MR6450 and a new MacBook Pro M2 both are able of Wifi 6e on 6GHz (tested that with other devices) but they just don't work together on Wifi 6e 6GHz. Why? Cheers Jörn...
jraffel
Mar 07, 2023Aspirant
No actually the MacBook Pro works totally fine with a AXE5400 Tri-Band Gigabit Wi-Fi 6E Router. Insane DL speed and nice Ping.
Mar 08, 2023Guru - Experienced User
So then I'm confused what issue you're having.
A little more clarity might help for what the issue is.
- Mouze64Jul 11, 2023Aspirant
I'm experiencing the same.
MacBookPro M2 works perfectly with my WIFI 6E rooter at home.
But the same MacBookPro with Nighthawk M6 Pro MR6450 (bought in France) doesn't even see the WIFI6 signal...
Please help.
- michaelkenwardJul 12, 2023Guru - Experienced User
Are you familiar with this?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
- Mouze64Jul 12, 2023AspirantI have the issue with macOS and not iOS nor iPadOS, but I’ll try
