jraffel
Mar 04, 2023Aspirant
MR6450 and MacBook M2 don't connect on 6GHz
Hi Netgear, I got the new MR6450 and a new MacBook Pro M2 both are able of Wifi 6e on 6GHz (tested that with other devices) but they just don't work together on Wifi 6e 6GHz. Why? Cheers Jörn...
michaelkenward
Jul 12, 2023Guru - Experienced User
W1lliam wrote:
Tried with NTGX65_12.01.05.00 with Dell laptop (installed Intel AX210) has no issue with WiFi6E connection, works as expected.
A lot of problems reported here with 6 GHz wifi have been down to the drivers for the WiFi. Dell and Mac are completely different.
I still think that plemans was on the right track.
W1lliam
Jul 12, 2023Virtuoso
Suggest to have MR6450 landed on PSC channel to see if that improves, I am having 2.4+6G set to WiFi profile
- Mouze64Jul 12, 2023Aspirant
I'm with 2.4 and 6
It's in VHT 160 for 6 = not visible
I tried VHT80 = same problem
I tried in HT40 = same problem
No other option available
- W1lliamJul 12, 2023Virtuoso
What channel you did for MR6450? Mine is working set on Auto and 37 (PSC channel), for VHT160
- Mouze64Jul 17, 2023Aspirant
Channel is on auto for VHT6O
But there is no parameter "PSC Channel"
- ArodiDalpzJul 14, 2023Aspirant
I tried both (with or without power plugged)
