SpaceCB
Mar 16, 2023Tutor
MR6450 with Orbi
Hello Community. My setup is the following: Netgear MR6450 with 5G Lan connected to my Orbi RBR20 that is serving mesh to 2 satellite RBS20 I am experiencing 2 types of issues: Intermittent i...
Mar 16, 2023Guru - Experienced User
Do you have the MR6450 in passthrough mode or the orbi in access point mode?
they're both routers and it causes a double nat if both routing functions are enalbed
- SpaceCBMar 16, 2023Tutor
M6 is not in IP passthrough and DHCP is on. , Orbi is set up in AP mode.
- plemansMar 16, 2023Guru - Experienced User
How many devices do you have setup?
you might try putting the MR6450 in passthrough mode and the orbi in router mode. it might be to many devices causing issues with the MR managing them- SpaceCBMar 16, 2023Tutor
thanks will try that... I do have a large number of devices...
