SpaceCB
Mar 16, 2023Tutor
MR6450 with Orbi
Hello Community. My setup is the following: Netgear MR6450 with 5G Lan connected to my Orbi RBR20 that is serving mesh to 2 satellite RBS20 I am experiencing 2 types of issues: Intermittent i...
JohnPeng
Mar 17, 2023NETGEAR Expert
SpaceCB wrote:
Hello Community.
- Intermittent intern access loss. during the day, several times, I am losing internet access for a few seconds to a minute. this happens about 5 to 12 times a day... not very cool while in a video conference call. I have no idea what could cause this.
- on my Orbi wifi, my cell phones (iPhones) are experiencing excruciatingly slow speed on wifi if they can connect at all. I disabled private address etc.. in their wifi setting and it's better, but they seem to struggle to access the internet.
I was hoping some of you may be able to shine some lights on this. it's really making it hard for us to work from home.
Thanks
Please try the following steps to help us find out what causes the data disconnection or stall.
1. Connect another WiFi device to MR6450 WiFi
2. When you experience data stall or disconnection, please check the other WiFi client whether it can connect to internet with decent speed. You can run speed testing with the client.
Please also capture a model.json file with the client connected to MR6450 and send PM to me for reveiw.
Then please try setting IPT via Ethernet by logging to WebUI. It will avoid the double netting issue when using the default setting as Router mode.
Thanks
SpaceCB
Mar 20, 2023Tutor
Thanks for the info. I am holding on to this, as it seems that moving the Orbi as a router and not AP has solved the problem. so trying this out for a week or two before trying to do more.
- plemansMar 20, 2023Guru - Experienced User
Hope it stays solid. I wouldn't be surprised if it worked better as that was quite a few different devices for the MR6450 to be managing. The Orbi has a bit more capability being a non-mobile device.
- JohnPengMar 20, 2023NETGEAR Expert
Thanks for the information that setting Orbi as router mode can help. Will check internally to see whether there is something we need to improve on M6.
Regards
John
